-   Ford Taurus (https://www.fordforum.com/forum/ford-taurus-26/)
-   -   code for keyless entry pad (https://www.fordforum.com/forum/ford-taurus-26/code-keyless-entry-pad-3657/)
flboy1025 Mar 21, 2006 12:05 PM
Hello all,
I have been everywhere with no help. I have a 2005 Ford Taurus SEL which has a keyless entry pad. I cannot find the manufacturer's code. Any help would be greatly appreciated.
Thanks.;)
billybroncojr Mar 25, 2006 10:38 AM
RE: code for keyless entry pad
I have a 95 with keyless entry and the code for the keypad is on the underside of the trunk lid.
Jeff
WASLYH Apr 13, 2006 03:02 PM
on some models( mine is a 2001) you can find the code,if not on the trunk support arm on the side of the computer which should be to the left of the steering wheel column..
you are gonna have to run the driver's seat all the way back,scrunch under the steering wheel shaft and use a flashlight to read the code of of the right side of the 'puter...
hope this helps...
