disabling abs system
Am experiencing a brake problem on my 1991 Taurus. Trying to determine whether my left caliper is sticking (it was replaced 2000 miles ago) or if the abs sensor is activating the brake. Is it possible to temporarily disable the abs sensor to see if the sticking stops? if so, how is that done? Any advice would be appreciated.
RE: disabling abs system
[sm=welcomesign.gif]To check it i would pull the fuse but would not recomend driving it. [hr]It does sound like the caliper is hung up. [hr]If the ABS system was at fault more than 1 wheel would act up.[hr]And the light would be on.Also make shure the brake hose is not kinked.
