Electrical window problem.
Thanks in advance to any/all that might be able to help out.
I have a 1993 Taurus; the problem is the passenger’s front window, it will not roll up. The driver’s control for the window will do nothing; the passenger’s control will roll the window down, but not up. I checked the wires on the driver and passenger switches, all looks good. I swapped one of the rear window switches for the passenger front, it made no difference. Thanks again for taking the time to read this post.
Hmm, electrical issues can sometimes be a real pita. When you said you "checked the wires on the driver and passenger switches, all looks good", did you just visually inspect them or use an electrical tester?
I think I remember seeing a recall or TSB regarding this problem. If someone can find it before I do, that'd be most helpful. I'm pushed for time time right, but will try to check back later.
