Help with 3.0
2001 taurus . Scan tool came up PO302. Misfire number two cylinder. Found torn plug boot. While changing wires I installed new plugs. Properly gapped at 46 and installed new wires. Double checked firing order and routing of wires . Disconnected battery to clear comp .check engine light no longer on and blinking but engine has miss and now pings on hard acceleration.. I thought maybe cross wire somewhere but all check out correct. This is a u coded engine and takes the short reach platinum. dont know if that makes differance thou . Help any ideas on whats next to check
RE: Help with 3.0
ORIGINAL: paultech6 2001 taurus . Scan tool came up PO302. Misfire number two cylinder. Found torn plug boot. While changing wires I installed new plugs. Properly gapped at 46 and installed new wires. Double checked firing order and routing of wires . Disconnected battery to clear comp .check engine light no longer on and blinking but engine has miss and now pings on hard acceleration.. I thought maybe cross wire somewhere but all check out correct. This is a u coded engine and takes the short reach platinum. dont know if that makes differance thou . Help any ideas on whats next to check :eek: Check you Coil Pack for any Cracks....You may have a bad Coil Pack...Then recheck the firring order. |
RE: Help with 3.0
Thanks Sterling . The coil pack was bad.
paul |
RE: Help with 3.0
ORIGINAL: paultech6 Thanks Sterling . The coil pack was bad. paul :eek::D:D Glad to help...and I hope this works well for you |
| All times are GMT -5. The time now is 08:09 AM. |
