power windows/door panels
I had a problem with my driverside power window.I rolled down but wouldn't go back up. I messed with some wires inside the door panel ,looked for the fuse .no go. i tried later that night and it worked .any ideas?
Ford is infamous for master door switches failing. Since it started working again, I would look at the switch. If you are4 mechanically inclined and have patience, you can take the switch apart and clean the contacts. It is free, just costs a little time.
| All times are GMT -5. The time now is 05:16 AM. |
