radio / 6 cd player replacement
2000 ford taurus
I have a 6 cd changer in armrest that is not working. I cannot find the fuse but radio still works ok - does power go thru radio? Anyway, I am thinking of replacing this setup with a ford radio / cd unit in dash instead but not sure if the wiring will work. I could just replace the 6 cd changer with another one. Also, would it require any dealer setup on the pass code type issue? |
The CD changer is controlled through the RCU in the trunk. Power for the changer comes from Fuse 117, which is a 20 amp fuse in the Battery Junction Box.
