Taurus accelerates when put into drive
  #11
Old 08-04-2013, 10:47 AM
I don't know if I can be of any more help than what has already been suggested.
Does the vehicle have cruise control?
If yes, see if you can disconnect it from the throttle linkage and see if the problem is still present.
Sometimes the cruise components can get to malfunction and cause problems like this.
If it does correct the problem, let us know , then we may be able to suggest where to go from there.
  #12
Old 08-05-2013, 03:52 PM
merron41's Avatar
Default Fixed my Taurus
I wish I could tell you what fixed it. The IAC checked bad, so I changed it, but it did not seem to make a difference. I disconnected the cruise control cable, and again no difference. I cleaned the MAF, tightened all intake bolts(were not loose). I drove the car to work, and used the cruise control, when I disengaged to CC everything worked fine, and has for two days and 100 miles. Sorry I don't have a better answer.
  #13
Old 09-15-2013, 06:07 PM
primem's Avatar
this thread must have jinxed me. had a similar problem today on the wife's 06 Taurus. After inspection, the cruise control linkage had popped off and was holding the throttle plate open.
  #14
Old 01-06-2014, 11:20 AM
schroensr's Avatar
Mine did the same after I just had the tranny replaced .
  #15
Old 02-15-2014, 06:17 PM
schroensr's Avatar
After looking closer I had a recall on my throttle control cable . Had it replaced an the same thing .
  #16
Old 02-15-2014, 06:19 PM
schroensr's Avatar
I chucked it up as it's just a Ford . lol I liked it better when you did not have to rely on computers . Even they brake down . But more expensive to fix .
  #17
Old 12-30-2020, 06:39 PM
Robert Day's Avatar
Default Had same problem
So i had this same issue and I replaced the coil pack and it fixed it, it was good for a couple years but it seems to be coming back.
  #18
Old 06-30-2021, 11:16 PM
Bassir's Avatar
Default 2004 Ford Taurus reving high on its own
My 2004 taurus in the middle of road , specially after going over 50 mph, it revs automatically. I have to apply brakes hard & hold the brake. Otherwise the car will fly.
temp fix is come to stop; put it in Park gear; press gas pedal hard a couple of times, then it goes back to normal.
i think there is a gas pedal sensor or cable that needs to be replaced. But not sure what in the pedal mechanism needs to be replaced.
  #19
Old 07-01-2021, 08:58 AM
You could be right, however, we usually try to eliminate any items one at a time so we don't wind up replacing a lot of good parts.
Until all the linkage is verified working normally, not good throwing parts at the problem. Guessing can get expensive and disappointing.
martinford
09-14-2022 10:07 AM
hiyudon
08-18-2011 07:23 PM
crash702
10-26-2008 06:19 PM
andrew123
01-03-2007 12:02 AM
andrew123
01-03-2007 12:02 AM
Quick Reply: Taurus accelerates when put into drive
