trans problem
Old Jul 9, 2007 | 06:03 PM
jamey624's Avatar
Default trans problem
Cars does fine for about 20 miles. Then if i stop it wont go forward. If i put it into reverse than drive again it will go. It also clunks pretty hard when i do that. Not sure how to retrieve any codes either. What could be going wrong with it? Its a 94 Taurus GL 3.8 v6 auto
Old Jul 14, 2007 | 07:05 PM
davisead's Avatar
Default RE: trans problem
Your Tranny is shot. Mine (98 Merc Sable, 3.8L V6) was slapping hard into 1st & downshifting same way. I put a bottle of Lucas Trannsmission fix in that has helped, it only shifts a little hard when downshifting. No way around it though, it needs a rebuild, plates must be worn out...
Old Jul 16, 2007 | 07:36 AM
Use Common Sense's Avatar
If it's the original tranny, it possible the forward clutch piston failing. You probably have the AX4S tranny in your Taurus since you have the 3.8L V-6. Ford didn't resovle the problem until 1995 model year when the finally built the clutch piston out of steel instead of aluminum
conanalois
Aug 31, 2013 06:16 AM
larmak90
Oct 22, 2007 09:46 AM
RangerPA
Nov 4, 2006 01:31 AM
Seirpin
Oct 9, 2005 10:24 PM
xkikbxr
Oct 22, 2004 03:15 PM
