Oil leak at air intake w/ pics - 02 Taurus SES 6 cyl
Not sure what's going on here...
You can see enough oil in the cup there where it's pooled on the bottom. Is it normal for oil to be here? And if not what's causing it?
Yes,, the crankcase pressures or blow by (small amounts of oil vapors) are moved through the PCV and into the intake to be burned under normal combustion. In the days of old, the ‘blow by’ was just vented to the atmosphere.. Small amounts of oil deposits in the fitting would be normal...
The elbow degrades over time with heat and oil causing the cracks...
