93 probe se 2.0l air bag code 32
"Air Bag - Lamp Displays Code 32... Driver's side air-bag / safing sensor: high resistance or open " how do I correct this error?
RE: 93 probe se 2.0l air bag code 32
i believe they are referring to your clock sensor i had a e 250 with a similar code and definition high resisitance....
clock sensor??? Never heard of that. How can I clear the code? Is it possible to replace the clock sensor?
the code cant be cleared until the problem is fixed your air bag system does a self check every time its started if you disconnect your battery to try to erase it will be right back on clock spring is not hard to change. |
