94 Ford Probe GT
OK nice problem here for one thing the air bag light thanks to a mechanic that knew nothing flashes 4 times then stops then flashes 5 times, then to top it off what started it all was him trying to trouble shoot the A/C that kept cycling, So he pulled out the A/C relay and jumped it now this crap, well now the A/C compressor gets no power unless you run a jumper from the ground on the A/C relay to the low pressure switch, and this is supose to be a mechanic haha can anyone give me any ideas of what is going on or where to look thanks.
RE: 94 Ford Probe GT
Air bag code 45 says that the front sensor isnt mounted to the vehicle properly. Try swapping out the relays and see what happens.
The ac cycling on and off every few seconds is a sign of low refrigerant. Dont let this guy touch your car ever again, lol. |
On The Job Training [:'(]:D
i would take it back and make that mechanic fix it....[:@]
indeed lol! But as for the low refrigerant that was not the case! as he charged the system and it still did it this guys is a complete idiot lol! Ill get it worked out it goes to the shop to check out the electrical on monday. thanks for the replys
