no fuel
I'm new @this fuel injection crap, the probe ran out of gas .Now the darn thing wont start .Yes I put gas back in it ,removed the fuel pump and bench checked it .It works ,I also checked the inertia switch in the back ,the button was down .So where the heck is the fuel pump relay, and is there anything else I should check I am not getting any power to the pump.
RE: no fuel
Hi, just wondering if you got the probe figured out. I have a 93 with the same problem tried everything I could find. Have changed the relay, inertia switch and now here it could be a problem with the distributor.
Found a spot on the internet that said you could use the ignition HEI from a GM, tried this and it didn't work either. Would be interested in hearing what you have found. Kas |
RE: no fuel
Just to let everyone know, found another site with the HEI conversion and it worked like a charm. Now have 93 Probe running great with HEI ignitor out of a 74 nova 350 ci.
