-   Ford Tempo/Probe (https://www.fordforum.com/forum/ford-tempo-probe-39/)
-   -   noise when engine is turned off (https://www.fordforum.com/forum/ford-tempo-probe-39/noise-when-engine-turned-off-1536/)
mccall33 Aug 17, 2005 05:49 PM
My 94 tempo runs great--the only thing is when I turn off the ignition I hear a grinding or rumbling noise that seems to be coming from the air filter section. Have replaced the air filter to no avail. Any suggestions? Thanks :) mccall33@msn.com.
cctxfish Aug 17, 2005 09:45 PM
RE: noise when engine is turned off
Hey Sam,,
Sure it not coming from the cooling fan or starter bendx?
Patrick Aug 18, 2005 06:40 PM
also, if you have an open air element, when you shut it off, it will make a sucking noise
Ramrod48 Aug 19, 2005 12:48 PM
yea kinda sounds like cooling fan , of course the brg's on the hamster wheel may need lubing
Ramrod48 Aug 19, 2005 12:51 PM
Do you have AC on the vechile , I have heard them make strange noises when you shut them off.
mccall33 Oct 4, 2005 04:16 PM
Yes I do have AC--will check that--thanks
mccall33 Oct 4, 2005 04:18 PM
Will check that also--thanks
mccall33 Oct 4, 2005 04:25 PM
I am not sure--sounds like it is coming from the air filter area, but will check what you said--thanks very much!
mccall33 Oct 4, 2005 04:43 PM
Thanks for replying--will try that also--
