probe airbag code 34
Hi, I trace the code 34 and it says something about safing sensor circuit short. I'm not sure what i should do to fix this problem. not sure where this safing sensor is located. help please!!!
RE: probe airbag code 34
do you have a repair manual?
where you recently in a accident,the safing sensor should be in the middle of the front rad support check to see if it is disconnected or if it has come unbolted it will set a code it has to stay secured.
| All times are GMT -5. The time now is 08:50 AM. |
