still no power to fuel pump
ok is there anyone out there that can tell me if there is a relay or fuse somewhere between the ignition switch and the inertia switch? Maybe I'm looking in the wrong place .
RE: still no power to fuel pump
well thanks guys you were so much help ( not )I found the problem on my own short in wiring harness and hot spot in fuel pump making it work infrequently .
Cool , glad to hear you got it going , also their bad about having a problem with the connecter plug going to the top of the tank ,
see quite a few that the plug has melted from excessive heat from a bad connection, usually you can get away with just cleaning up the connecter an squezzing them a little tighter ,also on the ground side of the plug Ive found loose that will give you a intermitt start . make sure you use some di-electric grease on the terminals |
