water pump
how hard is to change the water pump on the 1993 Probe SE 2.0L
RE: water pump
Not terrible if your a mechanic. I just replaced the oil pump, water pump, and timing belt on my 93 probe. Well I haven't completely finished the project as I think I stretched the timing belt tensioner spring too far and am going to replace it to be on the safe side. If replacing the water pump you might as well replace the timing belt too as its in the way of the water pump. I would also replace the front seal and the two seals on the cam shafts as well. I would say it could easily be done in a day by someone who has some mechanical ability and a repair manual.
Todd |
