1987 T-Bird 3.8L V6
I just bought an 87 Tbird last week and I wanna make sure it stays in good shape. It has 120k miles on it and seems to be in a pretty good condition. I changed the
- Serpentine belt - Oil and oil filter - Air filter - Fuel filter Im gonna change - The distributer cap and rotor plugs wires. - Check Ignition timing - Check the CV boot - Radiator hoses - PCV Valve - Test the Alternator A website said I should check the Heat Riser and Evaporative Canister as part of a tune up. Did this come on my car? It was kind of a general tune up for older cars. Also what else should I look for or tune up? Im not all that good with cars but id like to become knowledgeable. Any help would be appreciated. Thanks -Eric P.S. Im bringing it for an inspection in a few days aswell so the faster the suggestions the more helpful it would be |
RE: 1987 T-Bird 3.8L V6
Bump
Anyone around this forum? Or is it another forum no one goes to anymore |
Try replacing the EGR valve and tube. Check fluids for proper colors. Brake fluid should be clear or yellowish clear to be any good. Trans fluid in automatic red , brown is bad. Motor oil yellow - black is shot - and check for any metal (fine filings) left in the drain pan when you change oil. Don't forget to check brake pads and rotors/drums.
Funny you say that when I changed out the distributer cap rotor plugs and spark plugs I accidentally broke those ****ty EGR vacuum hoses(I think thats what they are) so im heading up to an auto parts store to change out the hoses. imm getting an inspection too so I can check the back pressure on the EGR to see if the valve needs to be changed aswell. Thanks for the reply. I didnt realize these forums were so dead
