1989 blower speed problem
Old 03-16-2017, 04:48 PM
gironha's Avatar
Default 1989 blower speed problem
Hi everyone,
I have an '89. The heater/ac blower only works in the high speed setting. I would like to know if anyone can help me find the faulty part. I believe the fan switch itself is working correctly. I tested it and the contacts seem to be working. I haven't found the blower, but it looks like it is under the glove box area. The blower is working anyway. I haven't found an pics of what I am looking for. Can anyone help ?
Thanks,
Glenn
Old 03-16-2017, 04:52 PM
gironha's Avatar
Ok, I see now after posting that it appears to be the blower resister. Is it located behind the glove box?
Old 03-16-2017, 09:09 PM
Thumbs up
Welcome to the site...
Yes,, in the blower case. The default is high fan speed. When the lower speeds are selected/commanded with the fan switch, the voltage remains the same, grounding resistance changes within the resistors coils selected by the fan switch. When you pull it out, most often the thermal protection ( looks like a bullet shaped diode stretched between the coils) has an open. If you take a test lead and bridge the thermal unit where it connects to the resister unit,, all fan speeds should then work. Thermal protection is needed, so if it's open, a simple replacement resistor is the fix...
Old 03-16-2017, 10:19 PM
gironha's Avatar
Thanks for replying. Do you know if the resistor coil piece behind the glove box? I don't want to take that apart if it is not there. I have manuals for all my cars except that one.
Old 03-21-2017, 08:28 PM
gironha's Avatar
Thank you for the help. problem fixed. New problem posted.
Old 04-10-2018, 04:06 AM
perfectlift-tips's Avatar
looks like you just solved my mate's car problems. Thanks for posting the solution.
TrueBlue72
03-24-2013 03:34 AM
BMsuper
01-20-2011 08:44 PM
tomdsr
09-28-2010 03:29 AM
berniemack
04-02-2009 10:58 AM
SFPD770
10-24-2006 06:28 PM
Quick Reply: 1989 blower speed problem
