-   Ford Thunderbird (https://www.fordforum.com/forum/ford-thunderbird-34/)
-   -   1997 Ford Thunderbird Motor Mounts (https://www.fordforum.com/forum/ford-thunderbird-34/1997-ford-thunderbird-motor-mounts-13875/)
rizingstarz Aug 1, 2008 05:29 PM
I purchased a Chiltons manual for my 1997 3.8L T-bird to replace a motor mount and there is no mention or picture of the mount. Does anyone know how to replace a motor mount. (Driver side)
goinstrong Aug 14, 2008 10:09 AM
RE: 1997 Ford Thunderbird Motor Mounts
This F'n site won't let me post.
goinstrong Aug 14, 2008 10:17 AM
WTF? 11th time trying. 1 piece at a time. Disconnect negative battery cable.
goinstrong Aug 14, 2008 10:18 AM
Remove anything that could be stretched/broken or bumped into when jacking engine up.
goinstrong Aug 14, 2008 10:20 AM
This includes shift lever,wires,fan shroud,etc. Place a 2X4 under and across the oil pan on a jack. Don't lift yet.
goinstrong Aug 14, 2008 10:22 AM
Remove the motor mount through bolts to the sub-frame. Jack up the engine. Remove any accessories on the mount (oil cooler line clips).
goinstrong Aug 14, 2008 10:26 AM
Remove motor mount bolts to engine block. Remove mount. Re-assembly is reverse. Mount to engine bolts torque to 25-35 ft.lbs. Through bolt 35-50 ft.lbs.
goinstrong Aug 14, 2008 10:27 AM
Sorry for stretching it outI will go kickthe crap out of my computernow.
fblevins1 Jan 7, 2009 03:26 AM
ORIGINAL: goinstrong
Could have been a site problem, but you might in the future try going to "run" "CMD" ipconfig/flushdns and see if that helps, sometimes just going into tools/internet options/delete to clear your cookies and cache can help, but then again you would want to hurt me badly after that because you would have to enter your passwords into your sites all over again.
GoingStrong, I might seek your help in identifying a chassis part on my Tbird, but I will make my own post, rather than Hijacking this one.
diehard94 Aug 9, 2011 06:04 PM
thanks so much for the info,I haven't owend a t bird since my 60 and this 94 is alot to handle somany things going wrong.Do I remove both boltsfrom the frame then jack up the engine or can I do one at a time......this really sucks about the posting I also belong to a jeep forum and its not like this one hope I don't have to post in bits and pieces,thanks bro for the info
