78 Tbird headlight problem
Here it is, replaced switch because lights were cutting off after 10 minutes or so.
Now, they are still doing it. Help!! |
Hi Paul,
If everything is original,,,,,, and you replaced the headlight switch , and,,,, it is still opening the breaker in the switch, that is most likely caused by an excessive current draw in the headlight circuit.Might be a good idea to check the wiring from the switch out to the headlights, a wire may be pinched or possibly rubbing through to ground. You might check the fuse that supplies the headlights for a corroded or poor connection. |
| All times are GMT -5. The time now is 08:42 AM. |
