-   Ford Thunderbird (https://www.fordforum.com/forum/ford-thunderbird-34/)
-   -   Ignition Problems (https://www.fordforum.com/forum/ford-thunderbird-34/ignition-problems-845/)
84 SC May 4, 2005 09:17 AM
Ignition Problems
I have an ignition problem in an 1984 Sport Coupe
is there a switch somewhere inside the steering column which can short out ?
truckpuller May 5, 2005 01:16 AM
RE: Ignition Problems
The ignition switch is on the top side of the steering colum under the dash and controled by a rod from the key switch. I have seen the wire connector for the main feed come loose and get hot and melt the switch and cause bad connections.
Hope this helps and let us know what you find:)
copman1972 Aug 22, 2005 05:36 PM
IS IT A GREY AND CREAM COLOR AND SIT ON THE RIGHT SIDE OF COLUM
