transmission swap
I just purchased a '94 t-bird and I want to swap the motor into a street rod. It has an automatic now I want to add my t-5 trans to the 4.6 v-8. What flywheel will fit???????? What bellhousing will fit?????? The trans is a '93 t-5. The mustangs have 8 bolt flywheels and 6 bolt flywheels also tremac transmissions will anything interchange?????
I do not care about just mating the engine to the trans. Thanks in advance. |
RE: transmission swap
Are you positive it's a '94 4.6 and not a 5.0? I didn't realize the T-bird switched to the smaller block after the early 90's.
Originally Posted by supermac
(Post 775)
