02 Ranger 4x4 front differential pinion seal
Old Oct 21, 2007 | 06:59 PM
ryansteph's Avatar
Default 02 Ranger 4x4 front differential pinion seal
Front differential was leaking at the driveshaft. I replaced the pinion seal and refilled the diff. gear oil. This fixed the leak. This was my first time working on a differential. I am wonderingif installation of the pinion nut is the same as removal? Any info would be appreciated, thanks.
Old Mar 1, 2008 | 10:20 AM
grease_monkey1965's Avatar
Default RE: 02 Ranger 4x4 front differential pinion seal
any time you remove that nut you have to make sure it gets tightened down right it has a cruch washer in it and if the pinion is to tight you will ruin your differential your probably alright but if you start to hear a howeling noise i would stop driving it and get it apart
andresharris@yahoo.com
Jun 7, 2014 09:00 PM
shanes 04
Jun 15, 2010 03:34 PM
richmcdonald
Jul 23, 2009 12:54 PM
richmcdonald
Jul 23, 2009 12:48 PM
Superkick42
Nov 17, 2007 10:40 AM
