1973 ford f250 390 engine
My truck will start and run fine for bout 2 min then just turn off sometimes it will start back up other times it will just turn over.if i let it sit over night it will start right up and do the same thing.It has a Mallory unilite distributor put in a new coil new edelbrock carb.This is driving me crazy please help
All this started a week after it overheated
If you check for spark at the time it will not start it should provide a path to continue checking further.
At the time there isn't spark
Originally Posted by CasseySwartout
(Post 84344)
is the idea for getting the right suggestion and solution from an expert in form of any automobile techy will not help in making the trouble sorted out .. what i guess it will
Im looking for advice on what's wrong.Something in the distributor?
Don't know if this is the problem, but there should be a pick-up coil in the distributor that sends a signal to the module that the engine is turning over. You might check the wires coming out of the dist to verify the pick-up coil has continuity.
Even on a Mallory unilite distributor.Electrical stuff is kinda where im alil retarded
Put in new plugs and wires tonight started ran smooth then after bout a min died and just. Cranked gonna try the pickup coil in the distributor in the morning got to dark tonight
Fixed it needed a new Mallory led module. Thanks for the help
