1975 f350 wont start, NEED HELP NOW
Is there current on the solenoid when the ignition is turned to start? It should be tested on the "I" terminal(small one)? If there is not, check for a blown fuse, broken wire or bad ignition switch. It can also be the ignition switch adjustment is off not allowing current to the solenoid.
alwaysfordblue
Jun 25, 2009 11:07 PM
93f250xlt4x4
Jul 3, 2008 10:02 AM
