1992 F250 Tach Problem
Old Oct 16, 2012 | 06:42 PM
Runner's Avatar
Default 1992 F250 Tach Problem
I have a 1992 diesel 5 speed, and the tach is reading low rpm. Tach is working and will move but reading low rpm (I am guessing 700 rpm lower idel rpm shows 200-300). I replaced the tach sensor, checked, cleaned, lubed all plugs on right side, left side firewall, and behind insturment panel. Anyone had or have the same problem. I found the Ford Part Number 17360 which is the tach assembly for about $60 not sure if I should by it?
Doverust
Aug 14, 2012 12:30 AM
Dann74
May 31, 2011 03:25 PM
BENBROUGHTON1320
Dec 12, 2007 11:05 PM
myford92
Sep 29, 2007 08:37 AM
wayne1
Jan 5, 2006 05:12 PM
