1992 ford ranger 2.3L running very sluggish
hello,any help would be appreciated..i have the 4 cylinder
dual plug system.it runs ok until you come to a hill and even on level ground it doesn't have any power(get up and go)once you leave 4th gear.it has a small miss at idle,and does seem to maybe miss/surge in high gear(sort of like a lurching forward).with it idling i've pulled each plug wire from the coils one at a time,and what i find is that on the intake coil the #1 & #4 cylinders change the engine idling significantly,but the #2 & #3 cylinders are firing great from the coil but no change in engine.i've swapped the plugs around and stills remains the same.now on the exhaust coil,the #2 & #3 cylinders are firing but doesn't change engine,and the #1 & #4 cylinders have no fire at all coming out of coil.(and i already tried new coil,same exact thing)so that leads me to believe thats either normal or theres a problem before it gets to the coil..*just to note my engine lite doesn't come on at all,not even in the mornings when you cycle the key,hooked up the obd 1 and it says vehicle not responsive..tried it several times with same responce.could it be timing jumped 1 tooth or maybe the ign. module.any help would definitely be helpful |
RE: 1992 ford ranger 2.3L running very sluggish
id say the ignition control module would be a great place to start looking as it is what takes the command/information from the actual computer and basically tells the other engine systems what to do. i had done alot of electrical checking on my 91 explorer when i couldnt get it started after i had rebuilt it this past winter. I checked the EEC the ignition control module and basically from the module i was able to check the current going to the coil and the power going to the crank shaft position sensor and the power going to the fuel injection. if you do get into doing these checks be careful not to test equipment to wrong pins in the ICM or you may cause damage to the ICM and or other engine sensors or parts. when checking engine systems thru ICM you will be checking to see that there is power to the part your checking but also the fuel injection and the coil pack both receive a pulse to them i think from the ground source and that pulse is what tells the coils or injectors when to start and stop theelectric or fuel to each of the plugs and injectors. hope you get it figured out ..good luck to you
