1997 F350 Wipers
Hi All. Got an issue with a truck. Hoping for a little help. I just picked up the truck dirt cheap because it has some small issues. Trying to straighten them out. Problem Im having now is diagnosing the wipers. They wont do anything. Where should I start? Under dash fuse is good. Thanks for any help |
If the washers work and wipe, it would show the wiper motor is capable of working and possible switch problem.
If you get nothing there, you might confirm power is getting to the wiper motor AND that it has a good ground connection. One of the mounting bolts makes the ground. You might also make sure the sheet metal of the cab/body has a good ground available. Usually if still nothing , you could be looking at a rebuilt wiper motor assy. Most auto supply stores carry them. |
Ok. I’ll start with the power. There’s 6 wires in the plug for the wipers. Anysuggestions on which it should be for power? |
From the info I was able to find,
POWER=DARK GREEN GROUND= BLK LO SPEED=DARK BLUE/ORANGE HI SPEED= WHITE You can check the relays in the power distribution box under the hood if you have no power to the motor. |
