1998 e150 odometer stopped working
Odometer stopped working in my 1998 e150. Took cluster out and gears seem to be advancing fine. Everything else in cluster is working perfectly. I could replace the cluster but wondered if there was another quick fix. Possibly an external speedometer but not sure how to hook it up. Any suggestions would be much appreciated!
the speedometer sensor is located on the rearen
Thanks David.....is it the sensor in the middle on top of the rearend?
also would this work in my year van http://www.jcwhitney.com/electronic-...wx?filterid=j1 |
Yes that is it also check that there is no metal shavings in the rear end
| All times are GMT -5. The time now is 06:31 AM. |
