2003 Ford Taurus ALL windows not working
Hello,
I tried using my driver side power window today and it went down but wouldn't go back up. Then all the windows just stopped working. Is it possible that its just a blown fuse? I realize that it could also be the wiring in the door. But i'm hoping it's just a matter of replacing the fuse. |
I would check all the fuses first and then check to see if current is present at the switch and coming out of the switch. If current is coming out of the switch, more than likely it is a wiring problem. If there is current to the switch and none coming out, the switch is bad. Ford;s switch is suspect. They have a lot of problems with them. See if you can get another one to test with.
