2003 Windstar
Old 10-12-2018, 04:26 PM
daddyblaize's Avatar
Default 2003 Windstar
Who has replaced Timing cover gasket without removing engine?
Old 10-14-2018, 11:38 AM
It’s doable.
Close quarters, the cover studs need to removed to be able to lift the cover clear..
Old 10-15-2018, 01:34 PM
Default "It's doable...."
Hayapower thanks man I figured as much--I took one look and though the same. I've got a coolant contamination issue after having just installing this engine and I'm trying to rule out a bad engine. I'm going to make a plate out of some plate stock with a stencil of the water pump gasket a pressure valve will be installed and through it pressure applied to find the leak in the block.
daddyblaize
02-20-2022 10:34 PM
dplantz
01-04-2016 04:27 PM
junkyardjeff
05-21-2014 10:05 PM
obieone1
05-20-2013 12:28 PM
Brick
12-22-2005 02:40 PM
Quick Reply: 2003 Windstar
