7.3 Glow Plug Problem
1990 E350 168K: when turning switch on; glow plug solenoid (I guess that is what it is called; mounted on aft end of engine) clicks on, then 2 seconds later clicks off.
The only way engine will start is if I turn on & off about 15 times (each time holding for about 2 seconds). any ideas? |
RE: 7.3 Glow Plug Problem
possible needs a new relay
Did not want to buy one & install if that was not the case; becauseinstalled electrical products are not returnable.
Thanks Tater |
Right on: glow plug (solenoid type) relay. $150 from Ford, so I went to the recycle yard & got one for $35.00; cleared up the problem. Thanks for the input.
