88 bronco wont run after start
my bronco acts like its not getting fuel. one day it will start and run fine. then it starts for two seconds but wont continue to run? Fuel filter? does this have two fuel pumps, which one would cause problem? any other suggestions would be appreciated. Thanks for looking DAN
RE: 88 bronco wont run after start
intermittent fuel pump or more likely fuel pump relay, relay worth a try. ;)
could be injectors that need cleaning , they may be leaking off an causing the hard start , faulty connection on the wire plug to the pump,
