97 T-Bird on "Autopilot"
I've got a 97 T-Bird with the 4.6L. At times, my bird will go into "autopilot" mode: When I take my foot off of the gas, the engine will either continue to maintain the current acceleration rate, or occasionally when in 2nd or 3rd, will actually start speeding up. Braking to slow down becomes ALOT harder and gives me a front end shudder. When coming to a stop, after gearing down to 1st, RPM will jump up to 1000, requiring alot of force on the brake to keep the car stopped. Finally, when stopping to turn the motor off, the RPM will jump up to 1500-2000 when the shifter is moved to Park position.
This happens occasionally to frequently, sometimes while in the city and other times on the highway- there is absolutely no pattern as to the frequency, and there is no check engine light. Anyone?
It sounds like you car is having issues with throttle position and it may possibly be the throttle position sensor going bad.
The root of your problems is the fact that whenever the throttle is released the car isn't realizing that and it continues to maintain its previous speed instead of slowing down.
Symptoms of a Bad Throttle Position Sensor
toddinav
Nov 5, 2012 03:33 AM
paul4ut
May 19, 2012 06:54 PM
mystarcollectorcar
Mar 12, 2010 07:45 PM
