98 Explorer 4.0 P0171/P0174 troubleshooting help and a shocker!!!
Old Jan 11, 2010 | 04:20 AM
  #11
Use Common Sense's Avatar
Glad we could help and you're back in business.
Old Jan 24, 2010 | 12:31 AM
  #12
digital_diversion's Avatar
update....
running great and getting much better gas mileage...
no codes...
Old Feb 8, 2010 | 02:29 AM
  #13
glikark09's Avatar
Default 98 Explorer 4 0 P0171/P0174 troubleshooting help and a shocker
can you tell where he stopped typing and then copypasted? Sbcs tend to go real low oil pressure at idle at old age. its probably just idling too low and in effect, has no oil pressure. nothing out of normal. try changing the IAC idle air control valve and see if that helps any... also a fresh 100 tune up and a GOOD f.i. cleanse would help a ton. tpis at least the ones Ive seen tend to gum up real easy
Old Jan 27, 2013 | 11:29 AM
  #14
jv2000's Avatar
For anyone else experiencing the dual p0171 and p0174 codes here is a write up detailing some things to look at:
P0171 and P0174 OBDII Code Diagnosis
I have both codes logged in my '03 Expedition and have not found the cause yet ... the adventure continues...
Old Jun 20, 2013 | 09:10 PM
  #15
holamoc's Avatar
Default IAC carbon build up
I just had this same issue with my 2000 ranger 4.0. I cleaned out the IAC and BAM! Drives like a champ. It was about 2 years ago that I replaced it. I've got 260k miles and counting.
Hessmj80
Jan 5, 2021 04:14 PM
diehardgator1
Dec 11, 2013 07:21 PM
rmd8123
Jan 8, 2009 03:18 AM
riemer
Jul 24, 2007 03:46 PM
Bob Wells
Dec 17, 2006 11:24 PM
