abs
Old Mar 14, 2011 | 09:36 AM
tbspeed1's Avatar
Default abs
Hi all, can a faulty abs sensor in my 2000 f150 2wd v6 truck cause hesitation. Right after the light came on it seemed to almost miss at certain positions on the throttle, but only while moving. If I rev up the motor it sounds fine.
Old Mar 15, 2011 | 05:56 PM
way2old's Avatar
The ABS should not affect the engine. Does the "miss" seem to be at shift points under light accelleration? If it does that, look at the speed sensor on the top of the rear end housing. Also have the codes read by a high end scanner and post the code for the ABS and we can help more.
Hutch64
May 31, 2007 09:21 PM
jessie3
Aug 2, 2005 10:15 AM
gmm
Jul 12, 2005 07:35 PM
Cactus
May 24, 2005 12:59 PM
redfish32
Mar 20, 2005 11:31 AM
