-   -   Anyone have the same problem??? (https://www.fordforum.com/forum/general-tech-11/anyone-have-same-problem-1437/)
lobsteroll3 Aug 4, 2005 10:12 AM
I've been having problems inserting my key into the ignition. It will only go in half way. I have a zx3 2000 model. The first time it started was yesterday...as i was getting ready to head out early this a.m. the key just wouldn't co-operate w/ me =( Nothing broke off, i tested it w/ the duplicate key and same problem. Any insight?
Ramrod48 Aug 4, 2005 01:15 PM
RE: Anyone have the same problem???
Hummmm, might try putting a tad bit of dry grafite in it , not much , as it can be bit messy, dont get it on your fingers or clothes.then insert the key an work the switch through its diff positions several times should work . if not hit it again with the grafite an cycle swith again .
cctxfish Aug 4, 2005 02:46 PM
If lubeing it fails then just replace the key cylinder. You can take it to a locksmith and have them make it work with the keys you already have (for the doors sack).
lobsteroll3 Aug 5, 2005 02:29 AM
I had to have the car towed this morning...found out that there was a loose part..i forget the technical name for it but they had to drill it and replace the whole thing...ouch. almost $400. thanks for your reply...
