Bubbles in transmission fluid
When doing my Saturday morning fluid checks I noticed that the transmission fluid has bubbles on it. What is the cause
You didn't say whether the fluid level was above the recommended mark, was it?
bubbles in transmissiom
No it is at the correct level but am spotting
Was the trans warmed up when you were checking the level?
If the bubbles are air, an overfilled condition could cause that. Have you been able to tell if the bubbles appear to be air or possibly water? |
Definitely warmed up think I will drain and change filter and refill
| All times are GMT -5. The time now is 07:11 AM. |
