A/C Orifice Tube -- HELP!!
I have a 97 Grand Marquis. Where do I replace the orifice tube? A Mechanic told me it is between the cold ______? and the Hot_____? I assume this is the tube that comes from the compressor. He said it may be under the plastic piece on the very front of the car?
It looks pretty easy to install. I just dont know where it goes. Can anyone assist me with this or is it best just to take it in? |
RE: A/C Orifice Tube -- HELP!!
Welcome to the site..
Its in the line going into the evaporator/drier.. You'll need to release/remove any (pressure) charge, then use a disconnect tool to release the quick connect coupler.. The orifice can usually be pulled straight out with needle nose, wireect... Something wrong with the picture attachments/application. email me if you'd like to see the pic.. [IMG]local://upfiles/6756/75FC952E93284566A2B3B5D6F5E58AB8.gif[/IMG] [IMG]local://upfiles/6756/47C608D756984920BB829EE93A303083.jpg[/IMG] |
What was your car doing that made you need to change it maybe what wrong with mine is orface thing.
RE: A/C Orifice Tube HELP!!
I think it is buy the high pressure fitting.
