E350 won't go all the way into park
Old May 5, 2009 | 06:44 AM
E350turbodiesel's Avatar
Default E350 won't go all the way into park
I have been having trouble with my 02 E350 turbodiesel not going into park. Initially it was an intermittant problem but now it's constant. When the problem started I could get the lever into park with some effort. Basically the further I can go is Reverse and I can remove the key from the ignition and the steering does lock. I looked for a linkage adjustment on the transmission but it seems I have a cable with no adjustment. My mechanic thinks it's in the linkage in the steering column, I'm thinking I need a new cable. Anyone have an idea what the cause/fix is with this?
Old May 5, 2009 | 02:38 PM
Are all the other ranges/positions (other than Park) good with no position 'hunting' or excessive loose feel?
Old May 7, 2009 | 09:40 AM
NO seems everything is shifted one position to the left. IMO the "play" in the shift lever seems normal.
Old May 7, 2009 | 02:39 PM
Default upon closer inspection
I have to pull the shift lever back and towards 2nd to get it into drive. Once in drive, it's in the normal detent for drive.
maxpower
Jun 24, 2013 08:58 PM
Doneinne
Dec 22, 2011 01:21 AM
Doneinne
Dec 21, 2011 08:29 PM
boonestar
Mar 9, 2011 07:14 PM
E350turbodiesel
May 3, 2009 05:43 PM
