E4OD 2 wheel drive to 4 wheel drive
Is it possible to use a 1991 E350 diesel E4OD 2 wheel drive transmission and bolt on the 4 wheel drive components and use it in an E4OD 4 wheel drive diesel 1989 F350 truck?
Thanks Dave |
Tail Drive Shaft
I've been able to find out that I'll need to switch the tail shafts. The 4 wheel drive shaft is shorter.
Anyone else have any information? |
Yes, you would have to change the output shaft to bolt the transfer case up. To do this, you have to tear the trans completely down. It's a pretty big job. Hope this helps.
