Electrical problems after jump starting Ford Expedition
Old Apr 20, 2010 | 11:09 PM
easoueidi's Avatar
Default Electrical problems after jump starting Ford Expedition
Hello
I jump started my 2007 Ford Expedition Limited per the owners manual instructions and immediately following noticed the following problems:
  1. the AUX button no longer showed LINE INPUT as an option. It only shows SAT 1, SAT 2, SAT 3, and RSC ? (whatever that is).
  2. the Volume, Media, and Preset Radio Station button on the steering wheel also no longer respond
  3. the CD player gives me the CD ERROR message. When I press CD, it will say INITIALIZING for a few seconds, but does not work. Also, I have at least one disk in the 6CD changer that will not eject or play. When I start the car, the disk changer makes noises like it is trying to load or change disks, but nothing happens.
I have checked all the fuses at the Power Distribution Center and Fuse box. (Right front passenger and under the hood), but they all show to be good. I have also disconnected the positive terminal on the battery for 5 minutes and reconnected, but again no changes. Can anyone think of a solution, PLEASE?
BTW: I still have an extended full warranty through Ford. This should be covered, right?
Old Dec 30, 2010 | 10:26 AM
BigDinCA's Avatar
Sorry to resurect an old thread, but I have the exact same problem. And I can't find anything about it anywhere. I have also noticed a few other things, like the outside temperature display is no longer working and when I shut the vehicle off, everything turns off immediately. Normally the radio stays on for around 10 minutes after the key is removed, unless one of the doors is opened. I don't have an issue with the CD player though, that still works ok. I had to jump the vehicle after the battery completely died, but I drove it right to the parts store and put a brand new battery in it. The sterring wheel controls went out after the jump, and I noticed the other things after the battery rerplacement. The outside temperature display just showed up yesterday, 3 days after the battery replacement. I need some help!!!
easoueidi
Apr 20, 2010 08:59 PM
93f250xlt4x4
Jul 9, 2008 08:47 PM
daveranger
Dec 30, 2006 07:07 PM
rangerfx4l2
Oct 21, 2006 11:22 PM
