escort fan switch
I can't find the fan swithc aon a 96 escort. the fan won't kick on when it is supposed to. any help would be aprpeciated.[sm=smiley22.gif]
RE: escort fan switch
check the fuses to make sure it hasn't blown a fuse, not sure they have a switch except for the themostatic one that tells it when to come on and go off.
If you have A/C, turning that on should cause the fan to come on. Also, unplugging the temp sensor should make it come on. If neither one happens check for 12V on the plug to the fan.
(Don't stick your hand in there with the engine running. Start it after you've unplugged it) If no 12V, you may have a blown fuse, bad relay, corroded plug. If 12V, time for a new fan. |
Check here for diagrams, component locations, and help troubleshooting. GOOD LUCK
http://www.autozone.com/servlet/UiBr...rGuideYMMEYear |
| All times are GMT -5. The time now is 09:36 AM. |
