fiesta mk 4 amp wiring problem
does any one know where and how to run the power cable from an amp to the battery, im having problems finding a hole or place.
cheers ry |
RE: fiesta mk 4 amp wiring problem
there is several places on the firewall you may do that. Look and notice where the wires cross the fire wall in your car. There is usually one near the stearing column behind the brake and clutch pedals. And behind the vehicles computer module in the passengers side. You could always drill a hole but you would have to find a rubber stoper to secure the cable in the fire wall.
Have you tried to use the fuse panel. there should plenty of spare openings for an application. |
yeah, your going to have to drill.
