-   -   Fouling Plugs (https://www.fordforum.com/forum/general-tech-11/fouling-plugs-26234/)
AjzPop Jan 17, 2012 02:59 PM
Fouling Plugs
I just finished putting a new Cam (292 dur/.498 lift), a new edelbrock performer RPM intake and 600 cfm holley carb on my '68 302. After setting the timing to "0", I got it running. Fired right up! It ran fine, 2000 rpm, but it ran fine. I stopped at that point and the next day, I went to set the timing with a light, but the light was broke. Now I keep fouling plugs. I take some of the plugs out and they will be wet and wreaking of gas. I can clean each plug off, put them back in, set the timing to "0" but now it will fire up but wont stay running.
Also, I crank it but after a minute of trying, the battery dies and it wont crank.
Any ideas?
wellandpond-Steve Jan 19, 2012 07:08 PM
The high RPM idle and fouled plugs sounds like a vacuum leak. I didn't like the Performer RPM on my 302. It's power is at such a high RPM range that you have to change a lot of other things all over the powertrain. I liked the performer. You might fix your problem with timing or De-Jetting, but it sounds like vacuum.
AjzPop Jan 20, 2012 07:37 PM
It was the alternator. I'm excited! Gonna get it tuned in tomorrow.
