help
can some one tell me if the 4x4's have a different fuse box than the non 4x4's. I have a 99f150 4x4 and I can't find a fuse box diagram that matches mine.
RE: help
If you have an owners handbook the fuse position/amp ratings, as well as relay positions ect. will be there.. If you don't have the manual you can download or view one here https://www.fleet.ford.com/maintenan...ls/default.aspThere isn't a different set of circuit protection panels for the F150, (like the 250SD/250LD in 99) but will be option specific to build.. These illustrations should be correct for your application...
[IMG]local://upfiles/6756/58379BBFD3C04B1295B5625E48CC6393.gif[/IMG] [IMG]local://upfiles/6756/0D4242013E91438E8299565A6368DB6F.gif[/IMG] [IMG]local://upfiles/6756/40A618C97E99409DB39619A76A189DFB.gif[/IMG] [IMG]local://upfiles/6756/E5971F3A8A864AC2A957D8D48B3ABEA0.gif[/IMG] |
RE: help
thanks, thats the one i was looking for... too bad it didn't fix my problems...grrrrr.. i'm going to check the clock spring today and see if thats it...
| All times are GMT -5. The time now is 06:11 AM. |
