Help my F250 start
Old Dec 30, 2006 | 10:01 PM
saltydog73's Avatar
Default Help my F250 start
I have a 1991 F250 7.3L Diesel that has decided to stop starting... hopefully, someone here can make some suggestions. When I try to start the truck, the solenoid clicks once and then everything electrical dies. I had the starter bench tested at AutoZone and they say that it is fine, as are the batteries (tested also). I connect the two battery wires to the solenoid and leave it hanging rather than connecting it the fly wheel... one solenoid click and nothing. I replaced the stupid "Ford" solenoid on the fender of the truck (I don't know why Ford insists on two solenoids but that can be for another post) - one click solenoid and nothing. I took a jumper cable and went between the + post of one battery and the corresponding post on the starter's solenoid... this time I get one solenoid click, a few (5-6) cranks and then nothing. The wire on the jumper cable heats up and starts melting the plastic sheath (I think if it was heavy enough gauge that jumping the battery to the solenoid would work). My dad tells me to check all the cable connections (+/- wires)... I checked and cleaned all the (+) connections with a wire wheel on a grinder or sandpaper so they are all clean (bare metal). I didn't check or clean the engine or frame grounds because I think that if I had a ground issue, my battery to starter solenoid jumping would produce the same results as without the jumping... I did nothing to the ground when I run the jumper cable. My next option is to replace the battery cables... I call Ford and they want $300 for the cables (are you f-ing kidding me? I understand copper is expensive but how does the dealership justify that price?), AutoZone wants $110... note about the cable; the (-) cables are pretty standard, the (+) cable is connected to the left-hand battery, runs to the right-hand battery, and then splits. From here, one wire (16 gauge) goes to the "Ford" fender solenoid and then goes to the starter solenoid; the other wire (4 gauge) goes to another post on the starter solenoid. I am going to wait until Tuesday to see how much a battery shop can make the cable for me, but before I do that, am I missing something that I can check or change? Could my jumper between the (+) on one terminal to the starter solenoid really work if I had a ground issue? Again, when I do this, all the battery wires are connected as they would be from the dealership. I generally drive the truck to tow my boat only; this all happened when I took it for a drive (ran about 20 min) and then turned it off outside of a store... hasn't started since.
Old Nov 27, 2007 | 06:37 PM
david paul's Avatar
Default RE: Help my F250 start
DID U EVER FIGURE OUT PROBLEM SOUNDED TO ME LIKE BATTERY CABLE BAD THOSE THINGS CAN CORRODE INSIDE WHERE ENDS ARE MOLDED ON AND MAKES THEM HARD TO TROUBLE SHOOT
Old Nov 27, 2007 | 06:49 PM
saltydog73's Avatar
Yes, I got the beast running. It turned out to be the positive battery cable; I had one made for $60 at the local starter and battery shop. A few months ago, I wound up replacing the stater as well. The truck runs great: starts on the 3rd or 4th spin of the starter and I haven't had any other issues. Not bad for a truck with 289k miles.
Old Nov 27, 2007 | 06:56 PM
david paul's Avatar
GLAD TO HERE IT I USUALLY BUY THE CRIMP ON ENDS BUT INSTEAD OF CRIMPING I SOLDER THEM ON WITH ROSIN CORE SOLDER AND HAVE HAD REAL GOOD LUCK AT THIS PROCEDURE AS LONG AS CABLES HAVEN'T BEEN OVERHEATED VERY MUCH AND IS A LOT CHEEPER THAN NEW CABLES GOOD LUCK
yotaism
Aug 19, 2010 12:42 PM
NYCArmyWife
Nov 16, 2008 12:29 PM
saltydog73
Dec 31, 2006 12:53 PM
6x6man
Apr 30, 2006 03:10 AM
JAKE065
Jul 2, 2005 02:19 AM
