i need help bad
Old 05-22-2018, 01:02 PM
Boone70's Avatar
Angry i need help bad
guys i need help badly i took a running 3.0 motor out of a 2002 ford ranger and put it into a 2001 ford ranger changed motor wiring harness along with pcm and engine bay harness and also changed the gem module all from original 2002 ranger and it will not do anything any ideas???
Old 05-22-2018, 02:30 PM
Well, let's see !
Sounds like you did everything right, except, the ign key !
Your original key will not work with the "new" pcm/gem.
It might work if you removed your original key tumbler and installed the ign key & tumbler from the 2002. There could be other reasons, but that is the first thing that came to mind.
Old 05-22-2018, 02:54 PM
Boone70's Avatar
Well, let's see !
Thanks for the reply .I failed to mention in the original post I changed out the whole steering column with the switch still in it from the 2002 ranger
MrSauga
09-19-2012 04:26 PM
rlpatte
03-31-2012 08:45 PM
greuelc
09-27-2008 03:07 PM
berbaby
01-13-2007 08:28 PM
rispeed
10-29-2005 06:09 PM
Quick Reply: i need help bad
