Ignition/Distributor Problem on a 1984 460
I have been having intermittent starting problems with my 460 powered RV so I replaced everything, the rotor, cap, wires and plugs. Then it would not start at all. I noticed one of the 3 wires (the yellow one) coming from the distributor had the insulation dried and broken off and the wire was grounding out.
I have a constant negative feed to the coil which gives me a very week and constant spark to the plugs and as I said, it will not start.
Could this yellow wire grounding cause something to malfunction and is this the cause of the constant negative feed?
drybasement
Oct 19, 2013 09:00 PM
wetracer
Feb 15, 2007 02:10 PM
1984, 460, backfires, distributer, distributor, f250, ford, ignition, intermittent, issues, photo, problems, problens, starting, trouble
