keyless entry help
I just bought a 99 Crown vic and need to program the keyless entry. The book says to enter the factory code setting and then I will be able to enter my on code. Only problem is that the previos owner does not know the code from the factory nor do I have any paperswith it on it. Any help or suggestions....
RE: keyless entry help
if you go to the dealer they can hook up the wds or ids and give you the code when i worked at the ford dealer we would usually do it for free just to keep a customer
ORIGINAL: Dallas 17 I just bought a 99 Crown vic and need to program the keyless entry. The book says to enter the factory code setting and then I will be able to enter my on code. Only problem is that the previos owner does not know the code from the factory nor do I have any paperswith it on it. Any help or suggestions.... |
| All times are GMT -5. The time now is 09:58 AM. |
